s13 starting question
Old Sep 7, 2009 | 08:41 AM
Evilsnowman137's Avatar
Default s13 starting question
Everytime i start my car from a cold start over night a belt skreeches really loud for a couple seconds then stops. When it does this the car seems to like to start up all the way until the belt stops wining. Anyone have any ideas. I figure i should go change the belt, but will that solve it.
Old Sep 7, 2009 | 10:32 AM
DA92driver's Avatar
Try adjusting the tension on the belts tighter. No luck? replace the belts.
Old Sep 8, 2009 | 09:03 AM
word. Also do you know where i can find a book that goes through most of the basic repairs. I need to tighten my clutch peddle alittle since it is sticking and also i think i may have a overheating issue. any help with this would be great since im stuck in tallahassee were there is absolutely no shops around at all.
Old Sep 8, 2009 | 10:25 AM
hillbillydrifter's Avatar
Get a Haynes or Chiltons manual from Advance or just download the Factory Service Manual(FSM) off the interwebs.
Old Sep 8, 2009 | 12:29 PM
thanks
Old Sep 8, 2009 | 02:56 PM
DA92driver's Avatar
clutch pedal is sticking as in to the floor? you may have a leaking clutch slave cylinder...
Old Sep 8, 2009 | 05:06 PM
4wheeldriftS13's Avatar
February - Ride of the Month
lmao.
RIP Tim Aldrich
Old Sep 8, 2009 | 06:48 PM
not to the floor haha. it sticks on the way up. its after the engagement point like a slight stick that doesn't make it come all the way up
