maxima starting problems
Old Sep 4, 2009 | 07:12 PM
coolchinklovingnat33's Avatar
Default maxima starting problems
i hav a late model of a 1994 maxima and one day it just wouldnt start.
today i ran a series of trials such as jump starting and push starting but nothing seems like it is working. i have checked all the fuses and everything on how to start it but i still cant get it to start. So i called some people and i found out that the button on the clutch pedal to press the clutch relay broke so i pressed it and then tried to start it again and it still wont turn over. what else could it be? it doesnt click when i try to start it , in fact it makes no noises at all. so some help would be appreciatied
Old Sep 4, 2009 | 07:17 PM
help please!!!!
Old Sep 4, 2009 | 07:26 PM
this car is my way of life
please help!
i need it done this weekend. if anyone knows anyone that can help me please give me a call. 727-902-6865
i live near clearwater high and the closer it is the better cause i cant even drive or even start it at all
Old Sep 5, 2009 | 04:25 AM
hauseclipse's Avatar
Team Warped Rejects
pull the plug off the clutch pedal switch and put a jumper wire between the 2 terminals.... see if that works....
Tim Diesel
HAI bike shop www.haibikeshop.com
freestyle ingenuity - www.freestyleingenuity.com
vortex sprockets - www.vortexracing.com
Old Sep 5, 2009 | 08:44 AM
Empire's Avatar
buildin' it
have you tried just hot wiring the starter?
take a wire from the positive battery terminal to the wire that comes off of the starter. That will tell you if the motor will turn over.
from there, put the key in the run position and see if you can get it to start that way.
If it does start, then chances are, your ignition switch is bad. Happens in older nissans. Pretty popular with 240s...
Also try that ^ jumper trick too. That switch is what won't let the car start if the clutch isn't all the way down. If that switch isn't working, then the car doesn't think the clutch is ever down and won't start...
Old Sep 5, 2009 | 07:05 PM
Default wow
thank you for all the help but none of them worked so i got a guy from aaa and the fucker was like well "what you have here is what happens when your car alarm goes bad" lol damn im so pissed
Old Sep 5, 2009 | 08:45 PM
Empire's Avatar
buildin' it
no shit huh...
well there ya go... at least now you know what to fix...
Old Sep 7, 2009 | 06:20 AM
Team Warped Rejects
damn man, thats an intresting one...
Tim Diesel
