what offset rims
Old Aug 16, 2009 | 07:32 PM
Blackzenki82's Avatar
(OO\____/OO)
concave FTMFW
those Bee*R's are sweet, just like the LMGT4's, and Rota P45R's
Originally Posted by sean1
Shit'll buff out.
Old Aug 16, 2009 | 07:36 PM
oASHo's Avatar
Lace Up!!!
gold ones are greddy gravitys. talk to 4wheeldrift to be on the zomg suckdickgreddygravitybandwagon
Old Aug 16, 2009 | 10:36 PM
-Mike's Avatar
Formerly IThaJokaI
10" wide, +1 offset has been done on a stock bodied s14. So go from there.
Old Aug 17, 2009 | 03:50 AM
Tony G.'s Avatar
ok fair enough those are some nice concaves. and thank you whattadobo for the size and offset.
Lost Prophets Racing & Performance
If you need a motor built let me know
Old Aug 17, 2009 | 06:49 AM
longfellow2's Avatar
FORE:sight
If you stretch the tires, your looking at something like -20 to -30. If you run proper spec widths then you'll need somehting around the 0 range. It also depends on what widths your running.
Alignments play a large factor in this. 1* of camber is 6mm (1/4inch) of movement at the top edge of the tire according to Epstein.
Your question is rather vauge since you've not listed a desired size or width of wheel.
Originally Posted by Epstein
Old Aug 17, 2009 | 07:44 AM
burgy240's Avatar
Offset-----Less is MORE!!
Offset is a direct correlation to how much camber you want to run, how much stretch you want, and how much fender work you want to do....there are too many components that go into it.
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Old Aug 17, 2009 | 10:00 AM
  #17 (permalink)
McLovin''s Avatar
Offset Is Everything
all you need to know is there is no concave wheel out there that will properly fill a 50mm wide fender on an s14. lip is the only choice.
after that, like longfellow and burgy have said, too many factors are left unanswered to give proper setup suggestions. But to give you an idea, I am running 18x11 -17 on the back of my s13 w/ 50mm fenders. Camber is not officially set yet, but there is a good amount of it.
Old Aug 17, 2009 | 05:29 PM
  #18 (permalink)
Tony G.'s Avatar
ok well i want something like a 10 inch rim in the rear. not sure what size tire that would put it at. Curious how wide you can go comfortably in the rear is my main question.
Old Aug 17, 2009 | 06:50 PM
  #19 (permalink)
trayfoe's Avatar
TIME OUT
Go here and look around. It will give you a good idea of what you want and what its going to take to get it.
rimtuck.com
tyrestretch.com
Old Aug 17, 2009 | 09:11 PM
  #20 (permalink)
McLovin''s Avatar
this is always a good guide too
