93 ka awkward idling, Help?
Old Aug 14, 2009 | 01:52 PM
DSMSpoolin's Avatar
Judge Fudge
Default 93 ka awkward idling, Help?
so just did the head gasket/timing/dizzy timing.
car was running perfectly fine for not having an 02 sensor.
after about 150miles of driving this problem is occurring.
now it bounces between 200-750rpms after like 15 seconds of idling.
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
Old Aug 14, 2009 | 01:54 PM
stage3_rx7's Avatar
I wanna be a baller.
Whoops, was signed in under neil's.
Its my 240 that is undergoing this problem.
1985 Dodge Conquest-SOLD
1990 Mazda Rx7 GTUs-SOLD
1990 Nissan 300ZX TT-Traded
1993 Nissan 240sx-Traded
1994 Ford Thunderbird SC-Totaled 6/11/10
1990 Nissan 240sx-SOLD
1995 Nissan 240sx se-SOLD
1994 Nissan Altima gxe-DD
Originally Posted by tissimo
No thanks on the rx7, spinning triangles are the work of voodoo.
Old Aug 14, 2009 | 01:57 PM
longfellow2's Avatar
FORE:sight
Check for vacuum leaks and plug your O2 sensor in.
Check your ignition timing, you might be off a tooth.
Originally Posted by Epstein
Old Aug 14, 2009 | 02:00 PM
stage3_rx7's Avatar
I'm pretty sure timing is correct, but should i retard or advance it?
The guy i got the car from welded the 02 plug closed?
i have positive crankcase pressure if that makes a difference?
Old Aug 14, 2009 | 03:14 PM
-Mike's Avatar
Formerly IThaJokaI
Dude, you need to get an o2 sensor bung put on. Or buy my stock header and plug one in.
Your crank case pressure has nothing to do with it.
Old Aug 14, 2009 | 03:37 PM
FORE:sight
You could be off either way, thats what a timing gun is for.
Get a vacuum gauge and check to see intake manifold has a leak
And get an o2 sensor on it.
Old Aug 15, 2009 | 09:19 PM
stage3_rx7's Avatar
you tell me you have a stock manifold after i leave your house?!?
the problem was fixed after installing a real intake pipe and being able to plug in all the vacuum lines.
