ac problem need help
Ok so my ac blows cold but it doesn't blow hard if I put it on 4 it will blow like if it was on 2. It makes a loud noise near the glovebox n it wouldn't even blow out the passenger went when its on 4.
Next problem is I have a switch manually for my condensor it blows colder when I have it off why is that?
Like us on facebook
Like us on facebook
you have a switch manually for my condensor? you realize thats in the front of your rad?
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Sullivan Racing LLC
352-665-2496-Tom
I got the car like that n yes its a switch to turn on the condensor
Like us on facebook
Like us on facebook
I used to work at an ac shop. The switch you are refering to is probably to turn the compressor on and off. the condensor is only for cooling like an intercooler or radiator and is not electrical. as far as the fan speed either the fan motor is going bad ie the noise you hear from the glovebox, it might also be the regulator i think that is what it is called it looks like a small cheese grader with a couple of wires to it it is located next to the fan under the dash both are inside the evap box under glove box. hopefully this helps.
yeah thats what i thought too, but ken the hatch is red it was that red one for 1200 but i picked it up for way less in the 3 digits area. also i think my switch is for the condensor im telling u its colder when its off n when i turn it on its gets a little warmer
Like us on facebook
Like us on facebook
so this switch...is for the condenser?...do you have a radiator switch too? it might be your radiator switch...i know my friend had a problem with his intercooler switch before...it wasnt switching on right...
http://www.hashiriya.net
