s14 troubles need help!
So after a year of farting around, I have almost completed my s14 project but I still need some parts in order for it to be finnished.
Does anybody know of a junkyard thats currently carrying an s14 thats not baddly picked off of? Or someone who has a s14 that they are parting out and that I may pick parts off of?
Heres the shitty cards I was delt:
I need the 8 bolts that connect the intake manifold to the head (KA)
I also need bolts for my right tension rod/tension rod bracket
Same with my left side but need the bracket aswell
Heres a picture of my KA...I need an s14 o2 sensor
and I need an open diff
I would greatly apriciate (I spelt that wrong lol) it if someone out there could help me in my time of need. thanks
s14/s13 intake manifold, and tension rod bracket bolts should be the same. The brackets them selves I am not sure about.
I think I have the first o2 sensor for an s14, Ill have to check.
Ace Hardware or Home Depot for the bolts, advance or ebay for the sensor.
you can have the intake bolts from my junk ka if you want to come pull them. the other ones idk, go grab some from an s13 at the junk yard.
That motor looks hella clean! Why didn't you remove all the egr/emissions bs?
