oil leak on headgasket?
Old May 19, 2009 | 12:48 PM
STORM's Avatar
Default oil leak on headgasket?
I'm still in the process of building my engine, but i notice that there is already an oil leak from somewhere and I have not started the engine yet I just put oil from time to time to make sure nothing rusts... the oil leak is from the apexi hg i got... where the badge is if i was to squize it there is oil on it... can it be that I did not put gasket maker around there? Or those 2 bolts on the sinde of the head are not tight enough?
Old May 19, 2009 | 03:26 PM
240Cyanide's Avatar
Function is my form.
bolts arent tight enough, maybe, or your head is warped
Old May 19, 2009 | 04:00 PM
180SX's Avatar
the 2 front real long 10mm bolts under the cam gears .. many many people forget them.
martin
Old May 19, 2009 | 06:51 PM
STORM's Avatar
does anyone know the tourge spec on those? thanks
Old May 19, 2009 | 07:08 PM
240Cyanide's Avatar
what engine is it?
Old May 20, 2009 | 07:54 AM
STORM's Avatar
s13 sr20det
Old May 20, 2009 | 09:57 AM
NeedCAforS13's Avatar
TOTALLY AWESOME.
Don't overtighten them either... those would be a bitch to get out if you broke one of them!
(O=O/-ROUGH WORLD-\O=O)
Old May 20, 2009 | 12:31 PM
240Cyanide's Avatar
i think its 110 ft/lbs i could be wrong
what did you tighten them to?
Old May 20, 2009 | 02:48 PM
180SX's Avatar
2 front bolts...lol.. they are are like 15ft lbs... they are not head bolts.. they are front cover bolt
\martin
