replacing clutch questions
Old May 3, 2009 | 12:12 AM
Empire's Avatar
buildin' it
Default replacing clutch questions
replacing the clutch on my s13, and I've got some questions
Do you need to/should replace the pilot bushing? or is it one of those, if it ain't broke, don't fix it things?
Can you clean the clutch plate? Its been sitting out for a bit. It isn't greasy or anything like that, its just been handled as its been moved around. I was thinking brake cleaner...
what are the torque specs for the pressure plate? or the flywheel? any tips on how to unbolt/bolt the flywheel so you aren't just spinning the motor? other than using an impact gun....
thanks!!
Old May 3, 2009 | 12:57 AM
nismokid's Avatar
The New Jessie James
thanks!!
I'd replace the pilot bushing...Your in there so why not? Just one less thing to worry about. idk bout the cleaning of the clutch plate or the torque specs but an easier way to take off the flywheel bolts, theres a tool for that. I've used it on all my trucks. Heres a pic...
Old May 3, 2009 | 08:20 AM
Empire's Avatar
buildin' it
that's what I was thinking about the pilot bushing, I just didn't know if it was really worth the work or not... Or if you ran the risk of damaging something else... ya know..
Assuming you could pick one of those up at Harbor Freight? What would one call that?
Old May 4, 2009 | 03:34 AM
ralph.'s Avatar
Your resident TR cokehead
yes you can spray down the clutch plate with brake cleaner.
torque specs:
pressure plate: 16-22 ft-lb
flywheel: 105-112 ft-lb
For 20 dollars ill call the guy a chicken fucker!!!!!!!
Old May 4, 2009 | 05:12 AM
robunicu's Avatar
Nicolai
just make sure u use a torch on the flywheel bols to they get really hot.. then they come out sooooo much easier.. and just find a friend that has a small compressor and impact gun... it will make ur life much easier... GL
PBM fender roller for rent!!
Old May 4, 2009 | 07:41 AM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
yes replace the pilot bushing, it sucks when it starts making noise. and it's not that difficult.
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
