sentra sr20det swap?
I am looking for technical info for this swap. stuff like diagrams of splices I need to make to the wirning harness what motor mounts to use axels and such. Basicly a walk through for this swap. every time i do a search it comes up with the 240 swap or sites that give no real info. any good links would be he;pful thnak you.
eric
eric
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
eric.
If you are swapping from a Sentra SE-R (91-94) then all you do is swap the motor.
you retain the entire SE-R drivetrain as in trasnsmission axles etc.
if you are swapping form a B14 Sentra you will need SE-R driveline to mate to your SR20DET.
rest in peace tim.
rest in peace tim.
Guest
Posts: n/a
What make model and year is your car? If you can tell me that I can provide you some instructions on the swap. Unfortuantely there are not any good resources on the web on the wiring and stuff. You will need an FSM and a voltmeter to get the wiring done on some cars.
Later
Later
I dont have a car i was looking for a friend that was thinking about doing one.. He wants a 91-94 b14 sentra...
thanks eric
thanks eric
eric.
eric.
SCC just did a swap guide in a G20 a couple months ago I have
the article if you need it
R.I.P. - Jason Harrill - 6/12/06
"Well, here's the thing".....you will be missed.
