dipstick question
Old Apr 25, 2009 | 05:50 PM
STORM's Avatar
Default dipstick question
I had to modify the way the dipstick curves, and now it just slides easily inside and out of the block. What can I use to seal it a bit better? Will gasket maker work around it? Thanks
Old Apr 25, 2009 | 06:04 PM
Blackzenki82's Avatar
(OO\____/OO)
get a thicker O-ring on the handle... that should solve it...
Originally Posted by sean1
Shit'll buff out.
Old Apr 25, 2009 | 07:33 PM
Jr_SS's Avatar
S one 4
^^^ What he said... The only problem is you might not be able to find the perfect size to fit it in the hole, so you may have to trim it alittle. By that I mean trim some rubber off the outside to make the OD smaller..
Old Apr 25, 2009 | 08:29 PM
STORM's Avatar
Wink
I mean where the tube goes into the block, not the stick going into the tube... thanks
Old Apr 25, 2009 | 11:15 PM
Empire's Avatar
buildin' it
then yeah, a touch of gasket maker (the copper stuff) ought to do the trick. go easy on it, its easy to use too much...
Old Apr 26, 2009 | 06:05 AM
(OO\____/OO)
i'd pass on the gasket maker, it's just too messy for the application, and also creates a bond, than once you pull the dipstick back out, it will pull away, leave excess...
just got to lowes or Home Depot, look for a larger O-ring, buy a couple of em, hell they're like $.40 each, and see which one fits, and if you're a jew, return the ones you didn't use, that way you don't have to trim, RTV, or any bullshit....
Shit'll buff out.
Old Apr 26, 2009 | 07:13 AM
Epstein's Avatar
Retired
There's no o-ring where he's talking about.
Yeah, a dab of any sort of sealant or adhesive will do it. It doesn't take much of anything.
Old Apr 26, 2009 | 07:17 AM
(OO\____/OO)
oh, okay, just saw that..... my bad....
yeah copper gasket maker might fix that....
my bad!!
Shit'll buff out.
Old Apr 26, 2009 | 07:59 PM
STORM's Avatar
ok thanks guys that's what I would do... its because I had to bend the dipstick because of the top mount manifold I'm going to use and it got really loose on the block. And I will need to even trip the power steering bracket because the manifold is even hitting that... thanks again for the great help!
Old Apr 26, 2009 | 08:35 PM
burgy240's Avatar
Offset-----Less is MORE!!
you should think with it...Jimmy!!
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
