SR wiring gurus help me play beerpong!
I pulled my motor to put a new head and hks cams on it, and freshen things up with new timing stuff, seals, gaskets, etc. While it's out I decided to paint my engine bay and clean things up. I pulled my harness to redo shitty connections etc. that are randomly in the harness from previous owners.
Here's where I currently am:
I will be sleeving the whole thing with the braided stuff, if anyone knows where I can get that?
Anyway, I've already gotten rid of a ton of useless s***, but right now have three questions.
Up first is this yellow/red wire. I pulled it all the way through from the passenger fender to pin #3 (Tach. signal output). Is this needed? My tach works fine I have no idea what this does because it goes to this weird plug looking thing and that's it. Here's a pic:
Next I have two blue wires that were chilling down by my ECU. The first one is blue with a black stripe. I followed it all the way to a coolant temp. sensor plug. Should this be pinned in my ECU? What's going on here?
The other blue one has a green stripe, and I followed it to the two plugs at the back on the intake manifold. I don't know how else to describe it so here's a pic:
So, let's get this mess off my table so I can play beerpong! My roommates are all WTFM8!?
2008 R1 | 2004 ///M3
Ok I got another damn blue wire. This one has a red stripe and goes to the same plug as the blue one with green stripe.
http://cableorganizer.com/nylon/
oooooh stainless!
http://cableorganizer.com/stainless-steel-braid/
super baller shit, this right here doesn't fuck around.... like yellow cake and aluminum tubes
http://cableorganizer.com/teflon/
google's working great at my house, must be down at yours
It's always beerpong at my house. If anyone is ever in Gville and you're not a douche hit me up and I'll show you what's up. We play like 6 nights a week, which is why I gotta get this cleaned up...we've had to start playing quarters baseball.
There is a cut Blue Green on pin 41 which is for AC on input...probably what you're talking about...for bumping up idle when you turn the AC on? (I also don't have AC). I don't see a blue and red on the ECU plug though.
If it makes it to looking like spaghetti during the construction, its probably going to be nice when done.
Yes this became a nice factory looking harness and is in a car down south:
R.I.P. Tim
RB $200
LS1 $250
RB $200
LS1 $250
