once again i need help lol.
hi tr i have another problem with my hatch when i first try to start the car it take me like two or three times and when im driving it,it dies onces in a while when i stop like at a light and when i shut off the car it stays on for like a second and then shuts off,can it be that my timing is of or what else can it be all of my injectors work.so if someone have any ideas lmk asap thanks u for ur time.
wow well you have had problem after problem with this car so far ur pissed lol..
check again for vacuum leaks.. then try messing with the dizzy or if you know what you are doing set it top dead center. if not google it.it is really easy
fuel pump, fuel filter.. Check them, then check your timing..
have you checked for bad grounds... it can cause it... mabey we abrubtly stopping a ground doesnt get a good conection and shuts the car off same with starting mabey its sparking and not getting a good conection... replace the battery terminals first its the cheapest thing... happen to my buddies hatch it would shut off at lights/stops and would take a few times to crank...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
hp~5!! trq-4!!
doing work!!!!!!
i replace does already but thanks for the idea,hey another question can i eliminate the top timing chain guide cuz i think the timing chain is rubbing against it i could hear it from the valve cover is not that loud but is annoying.
