rear HUB/camber issue??
Old Feb 20, 2009 | 07:36 AM
91180sr's Avatar
Default rear HUB/camber issue??
car is 91 hatch, on the rear left the camber is way more then the other side.. never ever hit anything and everything looks strait.. its on coils.. there set even everything else is stock..
also the wheel was working its self off the studs like it loosens up alot.. and brakes studs.. welded diff? I just need to fix it to sell so LMK if you have any info thanks..
Old Feb 20, 2009 | 08:06 AM
burgy240's Avatar
Offset-----Less is MORE!!
are you sure its camber and not toe??? or something else like that?
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Old Feb 20, 2009 | 12:34 PM
91180sr's Avatar
i know its camber.. but maybe its more could be little of both its just not right and i didnt hit anything nothing hit me no hard bumps.. no adjustable shit back there.... and i had it up looks strait..
Old Feb 20, 2009 | 12:58 PM
burgy240's Avatar
well more info would be needed, like was it once right and now off? before or after install of coils? how do you know it is camber? etc etc....
Old Feb 20, 2009 | 02:03 PM
IThaJokaI's Avatar
Hates cars...
Go get an alignment.. Stock parts have camber/toe adjustments.
the studs, I know with semi's if you let the clutch out harshly it can break them. I have never broken a stud or had a wheel come loose, so I can't help there.
Old Feb 20, 2009 | 03:29 PM
91180sr's Avatar
ill try to like to take a pic or what ever.. i just didnt understand snaping studs and i replaced them all then tightened correct and started to wobble and broke of 2 lol..
when ur looking form the back the left looks like its leaning way in on the top.. i dunno if its even the same problem.. could the whole side be pushed out of place?
Old Feb 20, 2009 | 03:32 PM
osama tim laden's Avatar
kings cannot fall.
if your toe is out, it will make camber more of an issue.
buy adjustable arms.
stock wont be enough.
Old Feb 20, 2009 | 05:23 PM
SmokinS13SR20's Avatar
That ginger...
Sounds like somethings bent, go get a free alignment check...
Old Feb 20, 2009 | 11:08 PM
91180sr's Avatar
ill try lol motors out for the week.. thanks guys.. anyone else lol
Old Feb 21, 2009 | 03:42 AM
burgy240's Avatar
agreed, camber alone shouldn't do any harm....
guys run it all day long without problems...but when coupled with something like a bent toe arm etc etc it could be really bad.
