R33 Rotors
R33 Rotors
I have a set of R33 rotors and I need some one that can re-drill them to a 4 lug pattern to fit my 240sx. Anyone knows a good machine shop.
Thanks
Thanks
are these the same size as 300zx 30mm rotors??
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Anyone know where I can get a set of front Gts-t R33 rotors?
OP-what calipers are you using with these?? by the way these are GTS-T rotors you have.
DAM! ok, looks like I may just have to buy them from there. Thanks
I drilled mine myself with a hand drill. It's not that hard, and you don't have to worry about screwing it up since the rotors are hub centric.
Jumping to the hot new thing so soon burgy? I remember reading about this upgrade in 1998 for ZTT's. MyNismo.com and Courtesyparts.com will both sell you OEM 296mm GTS-T R33 rotors (or get the R32 GT-R ones that are cross drilled). DBA distributors will also sell you several different models of the same rotor (ie: DBA4963 - 4000 series). You have to use the matching calipers that come with them; you can't use Z32 crap. The rears for all of these cars are the same as Z32. If you can find them, R34 GT-T's run 310mm 4-pots. Or be a real man and get the R33/R34 GT-R (also R32 GT-R Vspec) that's 324mm with Brembo calipers.
The R32 GTR are the same 296 but they are 32 mm instead of 30mm. I am doing the GTS-T on the front of the Q soon.
