Dented Frame Rails From Unproper Jacking
Thats exactly the problem, unibody means that the stamped sheetmetal formed into frame rails is also the same sheetmetal that comprises the body, there is no FRAME, which is why unibody cars benefit from things like chassis braces, subframe connectors, etc.
Apparently unibody has switched from being weaker and flexible, to hydroformed unobtainium alloy.
R.I.P. Tim
RB $200
LS1 $250
RB $200
LS1 $250
Well lets see who puts on these braces your talking about.... No one, so that pretty much means they are useless. If you want a more rigid car put a cage in it, If not then you dont need to worry about it.
Mustangs and f bodys use them thanks to there solid axles which twist the car under load. 240's IRS dosnt have the same problem. Anyone with coil-overs might notice the fact that the car will come off the ground almost instantly if taking an incline at an angle. If the car has so much flex that would be a problem.
If you want to reinforce anything do fender braces, thats the biggest weak spot of the car.
R.I.P. Tim
RB $200
LS1 $250
RB $200
LS1 $250
The Cyber Brain
on
Exactly what I was going to post.
Did 2 "H" braces out of tubular round stock from the subframe to the body pinch with a piece of 1/8" flat stock along the whole way and it made a huge improvement. IMO, anyone with a S13 vert should copy this as their first modification period.
