EVO/STi big brake swap. kills TT brakes DEAD
Old Feb 3, 2009 | 01:37 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
Default EVO/STi big brake swap. kills TT brakes DEAD
Not sure if this has been discussed. looks like people have been doing if for a while now but I've yet to see any local guys running this setup.
rears look pretty simple:
Rear STi brembo caliper on 300ZX rear rotors. cut off the dust cover, 1mm thicker STi pads are recommended, install brake line and boom, 297mm rears for your 5lug S chassis. as for an e-brake you can use the 300zx setup like usual. you can also use any Brembo equipped GT-R rotors and e-brake assembly.
rears
fronts are:
STi Brembo calipers on EVO rotors, cut/remove shield. but this setup requires a .5" thick bracket to be made. you can order the brackets from TIG Engineering for 290 shipped or make your own. so everything is literally "bolt on." as far as steel braided lines go (unneeded) you can order them for an STi.
It's recommended you use a better master cylinder etc.
TIG Engineering bracket
original thread is here, i just sorted through all the BS and posted the useful info.
Check out my new BIG BRAKES!! anyone else do this yet??? - Zilvia.net Forums
Old Feb 3, 2009 | 01:57 PM
presidential's Avatar
OG Join Date: 6-15-00
That bracket isn't pretty but it beats 290 bucks. What a rip-off. I guess you're mostly paying for engineering since it sure as shit isn't materials.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Feb 3, 2009 | 01:58 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
some people have too much money to care lol.
Old Feb 3, 2009 | 01:59 PM
Then I'll sell them one all painted metallic blue or something for half the price.
I've got a drill press...
1973 VW Squareback
RIP Tim
Old Feb 3, 2009 | 02:00 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
lol.
Old Feb 3, 2009 | 02:12 PM
Kung.'s Avatar
thanks for the dimensions of the bracket. lol
right clicked, saved.
Old Feb 3, 2009 | 02:27 PM
dan's Avatar
dan
Get the fuck off my lawn
because some of those brembos go for a pretty penny.
and it's basically overkill for 95% of the owners. w/o ABS it's lock city.
Old Feb 3, 2009 | 02:50 PM
longfellow2's Avatar
FORE:sight
Talk to Epstein, he had that set up on his car for like a year. And Chromedrifter had the same thing as well...
I was going to do the same thing but traded my STi calipers.
Originally Posted by Epstein
Old Feb 3, 2009 | 02:54 PM
cagedeyecam's Avatar
AERODYNAMIC WHEN I FIGHT
expensive stuff. BREMBO=PRICEY
I googled it , going rate was 750+ (just for calipers)
at this price you could go with willwood
Old Feb 3, 2009 | 02:58 PM
IThaJokaI's Avatar
Hates cars...
I need to run something like that on the front of my 929, my front calipers/rotors are garbage.
