ka idle bouncing between 1100 and 2000. what could be the problem?
Old Jan 29, 2009 | 06:00 PM
bearback's Avatar
nearly undead
Default ka idle bouncing between 1100 and 2000. what could be the problem?
my ka is idling horribly.
sometimes it idles at 11 or 13, then other times it will go up to 19 or 20.
any help is appreciated.
thanks a lot!
live to love the RWD.
89 seafoam coupe w/ SR20 and more- FOR SALE<- click
FAX
Originally Posted by Shadytrixta1
lulwhat? where? custom gutted? didnt know that was a mod unless of course we're talking vtec!
Originally Posted by sean1
if it has tits or wheels its gonna cost lots of money
______________________________
Old Jan 29, 2009 | 06:07 PM
nismokid's Avatar
The New Jessie James
I had the same problem, check for crossed vaccum lines.
Old Jan 29, 2009 | 06:24 PM
Speed cat's Avatar
speed cat
Idle air controller, auxillary air controller
Old Jan 29, 2009 | 07:21 PM
bearback's Avatar
nearly undead
thanks.
ill check both tomorrow.
anyhting else i should check if thats not the problem?
FAX
Old Jan 29, 2009 | 07:24 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
check you air filter tubing for any leaks
Drifting:
most fun you can have
with your pants on.
Old Jan 31, 2009 | 09:03 PM
bearback's Avatar
nearly undead
checked vaccum lines, how is the iac adjusted?
today i noticed that when i brake it goes down some, then comes back up at a full stop.
FAX
Old Jan 31, 2009 | 09:17 PM
A-ron's Avatar
thats sounds like a vacumme leak some where
Drifting:
with your pants on.
Old Jan 31, 2009 | 09:32 PM
bearback's Avatar
nearly undead
ill check them again tomorrow.
thanks
FAX
Old Jan 31, 2009 | 09:37 PM
ka24kouki's Avatar
Recreational Drifter
def sounds like a vacuum leak, never had it on my ka, but helped my friend out with his after he swapped his SOHC for a DOHC
