headlight issue
Old Jan 17, 2009 | 09:40 PM
240_kid's Avatar
Default headlight issue
Mike and I been trying to figure out why my head lights won't go down.
This is what we've done so far,
tested the ground; its good
Put the light down manually then tried to bring them up, didn't work
The wire for the sleepy eye I believe is cut but Mike wasn't sure if that was the right wire or not, under the dash is a bunch of wires that needs to be cleaned up because everything has electrical tape on it.
What should we try next?
Old Jan 18, 2009 | 09:34 AM
240_kid's Avatar
anyone??
Old Jan 18, 2009 | 09:54 AM
IThaJokaI's Avatar
Hates cars...
Plug in the wire that is for "sleepy eyes" and see if that helps.. If something is cut, plug them all back together.
Old Jan 18, 2009 | 10:53 AM
Matt Vassallo's Avatar
lifelong learner
press the 'headlight down' button
rest in peace tim.
Old Jan 18, 2009 | 02:00 PM
240_kid's Avatar
Nothing has worked yet.
Old Jan 18, 2009 | 02:31 PM
4wheeldriftS13's Avatar
February - Ride of the Month
If brown wire is cut your doing it right..any other wire; wrong.
Have you guys tried putting them down manually, then pressing the headlight up button or turning on the headlights on to see if they go up? If they don't turn on when the lights turn on try flashing the high beams..
RIP Tim Aldrich
Old Jan 18, 2009 | 03:27 PM
IThaJokaI's Avatar
Hates cars...
lulwut?
Old Jan 18, 2009 | 04:33 PM
240_kid's Avatar
I've done that already, that be the first thing we tried. But now thinking about it I think the brown wire was cut.
Old Jan 19, 2009 | 10:44 PM
elitist's Avatar
TR Balla Donor Supreme
^ i swapped in another relay, that didn't fix it, put the wire that is cut back, didn't fix it, tried replacing the plug, that didn't work, and tried putting them down manually then putting them back up, that didn't work, and yes, I've tried the headlight button... wow haha. Those are the first things i tried, i haven't messed with it lately though... I'll work on it some more this weekend
Old Jan 20, 2009 | 02:24 AM
art's Avatar
art
E=MC-hammer
this is kinda shot in the dark but somtime's this can be the issue, try replacing the colum switch somtimes the contacts get worn down and wont complete the circut it happens for the high beam's more offten but if you have checked everything eles its a good place to start also have you tryed working the headlight's with a direct 12v and bypass the system?
IM IN VA BITCH!!!!!!
www.rccustomz.com
