Brake problems help needed!
Old Jan 16, 2009 | 04:46 AM
Chris_2jz's Avatar
Exclamation Brake problems help needed!
Hi i have a friend who owns a ::95 (B14) Sentra GXE with no ABS:: who haves brake issues.
The problem: While he's driving without having to put much force on the brake pedal his brake are already locking up and forcing him to slow down. and now he uses the E-brake to slow down. and if he does touch the brake pedal his brakes lock up and he can move the car.
So if anyone has any idea of what the problem is please leave a comment on what you think it is.
Also: I been told he has bad brake calipers, but according to him there "brand new".
Old Jan 17, 2009 | 04:30 PM
Chris_2jz's Avatar
anybody?
Old Jan 17, 2009 | 04:36 PM
presidential's Avatar
OG Join Date: 6-15-00
Proportioning valve might be shot, I'd also look at the master.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Jan 17, 2009 | 05:15 PM
autoxcessna's Avatar
OBX Local
what ^ said
Old Jan 17, 2009 | 07:18 PM
Empire's Avatar
buildin' it
calipers might be bad, but I'd bet it is a bad master
Might also be something fun like air/water in the lines. everything heats up, causes the air to expand and put pressure on the brakes...
Old Jan 19, 2009 | 06:02 PM
redneck222269's Avatar
i had the same problem on my 89 240. calipers would tighten and only way to get moving again was to bleed the calipers manually. then i would be fine till i used the brakes again.... it ended up being the brake booster.. new calipers did not fix it nor did the new master lol alot of money but hopefully i helped you out with your problem lol
Old Jan 20, 2009 | 03:54 AM
Chris_2jz's Avatar
Im sure its not the porportaion valve cause that only controls the rear brakes but does anyone know a really good way to find out how the "brake booster" and "master cyclinder" is bad?
Old Jan 20, 2009 | 05:19 AM
Remove, bench bleed for the master. And put a vacuum pump on the booster to see if it holds pressure.
This is all common sense stuff. But if you're in doubt, just go ahead and start replacing shit at random.
1973 VW Squareback
RIP Tim
Old Jan 20, 2009 | 05:42 AM
art's Avatar
art
E=MC-hammer
have you adjusted the rod thar conects the brake peddel to the booster? it set's peddel pressure and swing. just a shot without seeing the car but worth a try.
IM IN VA BITCH!!!!!!
www.rccustomz.com
Old Jan 20, 2009 | 06:25 AM
And if the rod is adjusted improperly (too much pre-load), you can definitely damage the master.
1973 VW Squareback
RIP Tim
