Dynoed my Silvia at low boost
i have a stock block with nismo cams that suck ass by the way
never get fucking nismo shit it is sooo close to stock you hardly tell a difference
i hate it
man
your turbo isnt working if its not red hot
lmao
i hate it
man
lmao
rest in peace tim.
rest in peace tim.
oh ya one more thing dude
umm
1550 will probably be the max you want to go with a t3/t4 or t4
smaller turbos go 1700 sometimes
umm
rest in peace tim.
rest in peace tim.
We usually tune the cars to about 800-810 degrees Celcius on the dyno to insure a safe wide A/F ratio. Just incase the weather is too hot or something or the weather becomes to cold and overboosting occurs. With the conversion table being aprox. 9/5 The FarenHiet measurement should be around 1440 or so. That would be safe. Your 1550 is insane matt but I think we discussed why. You can tune it that high because of your really low comp ratio.
Just a photographer with a bunch of NIKON glass.
My Twitter: http://twitter.com/powersimagery
My Blog: http://powersimagery.com/blog
My Website: www.powersimagery.com
My Job: Vegas Magazine | Retna LTD | Tao/Lavo/Marquee Las Vegas
Guest
Posts: n/a
Ralph
The reason that you lose power by switching to the smaller turbine housing is because this introduces more backpressure between the exhaust ports and the turbine housing.
This increased backpressure decreases the volumetric efficiency of the engine making it harder to get air into the cylinders hence less power.
For example a T3/T4 on an SR20DE(T) will yield about 245 whp at 10 psi whereas a T25 at 10 psi will yield only about 195 whp. The smaller T25 has a smaller turbine and the backpressure is higher.
Switching to the smaller 0.59 A/R turbine housing will give you better spool up but the power will be down some particularly at higher boost levels.
By the way what cams did you get?
for all motors it is different i guess
im just saying works on the nissan turbo sixes such as L28 / l24 / Vg30 / Vg30D / RB20 /
from the guys ive talked to 1500 is a-ok
rest in peace tim.
rest in peace tim.
Guest
Posts: n/a
So are they stock GTi-R cams or are they an upgraded GTi-R cam? I think Nissan Motorsports (and Stillen) sell these.
Are you still running the hydraulic lash adjusters/lifters?
Let us know your new numbers when you hit the dyno again!
Peace
Peace
