s14 se radio Q's
Old Jan 4, 2009 | 08:15 AM
EnZo 240's Avatar
Default s14 se radio Q's
ok i got it all pretty much set up after an hour of trying to figure out what wire is what. every wiring diagram i found didnt match at all so i dont know if it was all re-wired or what. i have 2 questions first the ignition lead i read on one thing was a blue wire and on another it was a red/yellow one. the diagram that said it was blue was the one where the most wires matched so i hooked it up. i have the constant 12v but need the ignition one, i check blue then i check red/yellow and still no power (with ignition on) does this wire come straight from the radio fuse in the fuse box or some where else i checked the fuse and its good im going to replace it just incase some thing happend and we'll see. second question on se's they have to tweeters on the a-pillars do these speakers get the power from the door speaker of do they have their own wire?
i tried looking all this up and still couldnt find it lmk asap
Thanks
http://www.bmw.com/com/en/newvehicles/z4/roadster/2006/_shared/img/introduction.jpg
Old Jan 4, 2009 | 10:35 AM
IThaJokaI's Avatar
Hates cars...
Dont you have a multi-meter? Turn the ignition off, find the one that has power. Turn it on find the new one that has power.. and BAM you did it.
Old Jan 4, 2009 | 11:02 AM
Sohc4now's Avatar
^^^I'm with stupid
if you have the tweeters on the "a pillars" you have nissans premium sound package.
translation: all of your power wires, speaker wires, antenna wires (yes plural) plus a bunch of other shit which goes from the factory stereo to the factory amp, to all the speakers.
the amp is mounted under the rear deck lid.
there are diagrams floating around how to eliminate it
have fun!
Old Jan 4, 2009 | 04:45 PM
EnZo 240's Avatar
yes i do have a multimeter yes i do know how to use it and yes i did do that if i would have found the wire i would not have made a thread about it... i just ran a new wire and said the hell with it and i found the plugs for the amp all fubard and now amp but every thing works thanks n e ways guys
