Question between SOHC engines.
Old Dec 20, 2008 | 05:24 AM
BLK94EGCOUPE's Avatar
some nissan
^SOHC 240sx and Hardbodies both have crank driven distributors on the 00" frontiers the KADE is crank driven and the KADE on the 240sx is on the head
Old Dec 20, 2008 | 09:56 AM
Shadytrixta1's Avatar
has whippled VTEC
word thanks for the clarification i wasn't positive
Old Dec 23, 2008 | 10:49 AM
obituary's Avatar
TR OG
its posible that #1 WRIST PIN is wornout w/o smoke
he might not have readjusted the valves/lifters right?
idk?
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
Old Dec 23, 2008 | 01:36 PM
IThaJokaI's Avatar
Hates cars...
Originally Posted by drop_top_240
no... the truck single cam has throttle body injection.. you can swap the manifold over and i belive the trucks have a rear sump oil pickup as the 240 has front sump..and im not sure about pump placement but i know the dual cams in the truck have the power steering and alternators and such are all switched up
Fucking really?
A. SOHC hardbodies are NOT tbi, they are the same as 240sx motors with a top mount throttle body.
They are rear sump, with a hole in the block for oil dip stick.
You can run a truck block with 240 pick up and oil pan and 240sx and you will be fine.
Old Dec 28, 2008 | 07:47 AM
imkemk's Avatar
there are to different types of distributors for the 89-90 sohc ka24e the mitsubishi and the hitachi. make sure that the distributor, cap, and rotor are all the same brand.
