Electrical problem
So here's the problem.
Left my car on(not running key in the on position) for like 4 hours. Started the car up once in between. Well when I went to go start it up again...the battery was dead. No problem went to put another battery in and the car didnt start at all. So I jumped my car ran for 10-15 minutes...idled perfectly fine and everything then out of no where it started idling rough and died....well I turned the key back to the on position and nothing worked...not even the clock it was blank.
btw, when the car is off the headlights are bright as they should be...but there is nothing inside the car.
All the fuses and relay are fine.....the battery and alternator are fine.......
What do you guys think it could be?
Facebook
1993 Mitsubishi Eclipse GS - Lost - L
1990 Nissan 240sx - Totaled(r.i.p)
1991 Nissan 240sx - Sold
1990 Nissan 240sx - Sold
1993 BMW 325i - Traded
1990 Nissan 240sx TotaledTOT
2009 Nissan Sentra - Sold2005 Yamaha R6 - Sold
2006 Yamaha R1 - Stolen
2000 Nissan Sentra - Daily Driver
did u get the battery checked some times old batteries wont hold the charge from the alt.
and did u drive it cuz it might have needed the alt. to be putting out some high volts to charge it. i had a bad bat. and it did the same thing it started the idled kinda rough and when i gave it gas it wanted to stall out and then finally it died, but if it did that while it was on i would say some thing happend to the alt becuase if a car is on u can disconect the battery and the car would run on the alternator
