S14 Tranny Swap?
^ lol
5 speed transmission
Clutch upper and lower lines or agency power auto-manual line
5 speed driveshaft with carrier bearing, depends if your car is abs or non abs (shafts are different)
Clutch master and slave cylinder
Clutch pedal
Clutch, pressure plate, flywheel
Flywheel bolts, pressure plate bolts, pilot bushing, throwout bearing
shifter
5 speed tranny crossmember or drill out your auto one
cotter pin for clutch pedal
optionall shit:
5 speed trim, 5 speed ecu, transmission upper rubber boot, shift knob, 5 speed tranny crossmember, 5 speed brake pedal
Clutch pedal
shifter
optionall shit:
