I need some Wire harness/fuse help
Old Oct 13, 2008 | 04:23 PM
Speed cat's Avatar
speed cat
Default I need some Wire harness/fuse help
On the E.F.I harness there is a diode and a resistor and condenser electrical taped around the harness. I was wondering if it was possible if those can go out, and what negative effect it would have on the rest of the accesories on the other end of the harness from them. the resistor and condensor in the service manual is f35 for refrence. I had my harness go into the clutch fan and shorted something out....this happend 2wice on my harness and Im wondering if those 2 things are blown/can be blown even and what they help assist on the harness. also is their any major impact to say the ignition system or fuel system by fueses going bad under the dash on the drivers side. I havent checked what accesories those fuses go to, my tires flat, I don't ahve a flash light and its dark outside or I would have looked right now. 1 more thing, can any fuses under the hood impact fuel or spark or functionalty of the engine at all by being bad? alot of shits abreviated.
