KAT Help
no, you dont need a return. just let to flow out of the side of the turbo and drain out to the asphalt..
just block off the coolant lines on the turbo. seriously, it's not that hard. i ran an oil cooled t25g on my last car for almost a year and it was fine.
No, you dont block them off. You leave them open to the air. The coolant system is completely sealed.
Rear brake only for use when front brakes squeak whilst slowing for hot bitches
Its sealed, so what does it matter? Maybe the dirt / grime will help dissipate heat. Just leave them open if you dont want to run water through it.
