B14 Help needed
Old Aug 22, 2008 | 08:48 PM
ZdaMan's Avatar
Default B14 Help needed
I need some mechanical help.
My daily driver is having revving and stuttering problems when driving long distances.
Its a 95 200sx with the 1.6L engine with 202,000 miles on the clock. Everything was running fine until yesterday. I live a good 40 miles from work. When I got within 2 miles from my job I noticed the car was having problems and would not rev past 3500 rpms. When I left work everything was fine. Then I got about 2 miles from home and the same thing happened.
I'm about 70% sure its the catalytic converter.
Any suggestions before I put any more money into this thing.
Thanks
Z
Major props to Divine Sounds, Wheel Tec and Melilli Moto.
Old Aug 23, 2008 | 02:05 AM
steve's Avatar
madpom
thats not the symptoms of a bad cat
dose it stick of egg ?
Old Aug 23, 2008 | 05:39 PM
VoidDweller's Avatar
TR Balla Donor Supreme
You should be getting a check engine light. Pull the codes. If you are not getting a light, check your MAF. I don't have any experience with the GA motors, but that is where I would start with a FWD SR.
_____________
_______
04 TSX
97 240SX SE (SR20DET)
PM if you need B14, S13, KA or SR parts
http://www.engrish.com/
Old Aug 23, 2008 | 06:37 PM
Michael.Timz's Avatar
elevate your mental state
if you think it's the cat, unbolt it and see.
to the guy saying it's not symptoms of a bad cat, that's exactly what my friend's truck did when his cat was clogged up with carbon.
Old Aug 25, 2008 | 09:47 AM
ZdaMan's Avatar
Just got back from auto zone. Well barely. Its down to 1500 rpms with is 30mph in 5th gear. I'm sure I pissed of alot of drivers.
Anyways got a PO 100 and P0400 code. I was told its MAF circuit failure and EGR flow valve.
Looking at over $300 in parts.
Old Aug 25, 2008 | 10:11 AM
Here is a complete list of codes for your engine: GA1.6 Codes
Do some searching on that site to see if it's something simple like regrounding your MAF or replacing a sensor.
_____________
_______
04 TSX
