Help with Circuit Sports SS Turbo line install, i'm clueless ????
Old Aug 18, 2008 | 09:45 PM
kairojya's Avatar
Rojya Productions
^ and what did u do to fix?
mine could be, i'm not sure
Follow me: YouTube | Vimeo | 500px | Flickr | Google+ | Facebook
Old Aug 18, 2008 | 09:54 PM
im_DTF's Avatar
the 1 N only
i had to get an oil tee and run a steel line to the oil sending unit
Old Aug 19, 2008 | 01:10 AM
Epstein's Avatar
Retired
Yeah, don't strip the block side. That's a major pain in the ass to fix. FSM says 12-15 ft-lbs on that bolt. I'd go find some 12mm (inside diameter) copper washers and try again. 1/2" will work, too.
You're not out of the woods yet on the coolant lines. They don't pressurize until you've reached operating temp. That'll be around 13-19psi. The oil line was prob seeing 60psi at idle, though.
Old Aug 19, 2008 | 08:16 AM
kairojya's Avatar
Rojya Productions
yea i figured that on the coolant, was just trying to make myself believe i only have 1 problem left to fix tho lol. thanks for the size on that washer, i couldn't find any last time and i went to a lot of places.
i have 2 new nissan copper eye gaskets for that banjo bolt sitting at the dealership, those assholes closed early yesterday and i couldnt get them at 3:00pm when i drove 30 minutes there to pick them up FUCK
Old Aug 19, 2008 | 08:19 AM
kairojya's Avatar
Rojya Productions
sheit, well i'll see if its stripped, i hope its just the washers cause last time i replaced them and no leak
Old Aug 19, 2008 | 11:13 AM
kairojya's Avatar
Rojya Productions
tried to use the remaining copper eye bolt gasket i have off the turbo cartridge side hard line, i used it on the SS line banjo fitting on the block side and it still leaked, although it was a lot less.
I don't think it's stripped out, i guess i just need to use a brand new fresh washer and i'm gonna try that later today
Old Aug 19, 2008 | 05:11 PM
  #17 (permalink)
kairojya's Avatar
Rojya Productions
Ok so i believe i have it fixed and all set.
After trying numerous copper crush washers and none of them working, i tried the aluminum washers included with the kit and tightened down the banjo bolt maybe a 1/4 turn more then i was before ... so far no leaks! drove around for an hour and did a couple pulls and checked everything
i think it should be ok
Old Aug 19, 2008 | 05:42 PM
  #18 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
yay, oem nissan stuff is gay!
-Dane
98 240 w/ bolt-ons
Srqspeed.com
