4.6dohc Swap In A 240sx?
Old Jul 16, 2008 | 08:19 AM
AARONSredTYPE-S's Avatar
Exclamation 4.6dohc Swap In A 240sx?
I Have A 94 Lincoln Markviii With The 4.6dohc Cobra Motor And I Am Trying To Think Of A Monster I Can Put Together. I Know I Would Have No Problems Putting The Motor In A Fox Body Stang, But I Was Thinking Of A 89-93 240sx Instead.
If Anyone Has Any Info On This, It Would Be Much Appreciated Cause All I Can Find Is Everybody Doing Ls1 Swaps!
Old Jul 16, 2008 | 10:36 AM
presidential's Avatar
OG Join Date: 6-15-00
That's not truly a "Cobra" motor. I'd skip it and go for a 96-01 Cobra motor as it's aluminum instead of iron.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Jul 16, 2008 | 10:52 AM
IThaJokaI's Avatar
Hates cars...
5.4 with a kenne bell or bust... /thread
Old Jul 16, 2008 | 10:56 AM
jtmroczk's Avatar
All aluminium dohc V8 and independent rear suspension in anything = excitement.
All aluminium dohc V8 in anything = appreciation.
Iron block V8 in anything = bad weight bias or just heavy.
but i can still appreciate the work if you put the time in and do it right.
i quit because of administration, and because this place sucks...
VIPStyleCars.com/Awesomely bad idea
Old Jul 16, 2008 | 11:22 AM
Penis's Avatar
byah
I was talking with some friends about this. Why not just do the LS1? It would be easier obviously. Way bigger motor and way more power. Out the box you won't have as much HP or TQ as the LS1. There really is no point for the 4.6 motor. If you were going to do a 5.4 s/c or something than maybe.
TF Iron Lung Crew member #001
Originally Posted by Banksy
Clear papers make Jesus cry.
Old Jul 16, 2008 | 12:05 PM
umm, i already have the motor and tranny obviously, tyhats why i was wanting to do it. 300hp and lbft in a 2800 lb. car = faast, especially after its supercharged
thanks
Old Jul 16, 2008 | 01:55 PM
If it's a Mark VIII, it has 280 hp btw.
1973 VW Squareback
RIP Tim
Old Jul 16, 2008 | 02:07 PM
bvh's Avatar
bvh
wow ..um this is a aluminum motor and only different is cams and intake. 96-01 cobra motor go for 3 times more than a mark viii motor , so u can have a cheap cobra motor .
Old Jul 16, 2008 | 02:33 PM
Hmm, a factory forged crank v. a nodular cast crank is why I'd leave the Lincoln motor in the yard. You are correct about it being aluminum, I had it confused with the iron 5.4 I saw in a VIII I worked on once or twice.
Regardless, the first thing I would do is go and grab a tape measure and a note pad, see if it can even fit. Steering might be an issue (clearance with the steering shaft).
1973 VW Squareback
RIP Tim
Old Jul 16, 2008 | 02:43 PM
bvh's Avatar
bvh
that crank is good for 500whp .. but the rod and or pistons will break befor that . this is a good motor will hold 420whp for years . i think this swap would be cool , but it will take a bit of work and this guy sounds a bit green for a project like this .
