sr20det help
got my sr running awesome. got 255lph fuel pump, fmic, greddy type rs bov, etc. 10psi boost. runs and idles great. drive it... stop... great. run it hard and stop for a minute and it starts smoking. doesnt smoke under load, only at idle. and when its smoking and u give it some gas it smokes like crazy.... embarrasing. if i drive it normal for a bit it stops the idle smoking. btw... its oil. not fuel, not coolant....oil. compression holds evenly across the board. dont know if theres some typical sr20 thing or somethin. im thinkin its turbo seals, but im not sure how to tell(it doesnt have shaft play). ne info will be great and REP WILL BE GIVIN TO THOSE THAT HELP. thnx
I had the same problem, and thought I was going to have to replace the turbo but I was changing the oil the other day and looked at the oil return line coming off the bottom of the turbo and going in to the block and it had slipped a little letting oil squirt out a little and causing it to smoke. I'm assuming that yours has a small rubber line for your oil return like mine, if not then just ignore me. good luck
T28 is awesome because it bolts to the stock manifold. No need to buy another manifold. But requires different inlet and outlets. a/f will be an issue hints why people upgrade to larger injectors and a Z32 300zx MAFS sensor
