brake problem
Old May 30, 2008 | 08:53 PM
95hondaC's Avatar
Default brake problem
My 240 sat in the driveway for like almost 4 weeks with just the rear wheels on and jackstands in the front.. (long story) anyway, so i finally got all the wheels on and everything and took it out for a drive and realized after about a minute or two that i had no brakes at all.. the brake pedal just went straight to the ground. So i stopped and started pumping the brake pedal thinkin that maybe it just lost pressure in the lines or somethin but it didnt help at all. So then i checked the brake fluid and the level seemed to be fine.. looked a little dirty tho. Does anybody know what could be causing this problem? i replaced my struts/springs which required me to remove the top part of the brake caliper but im pretty sure i put it back together just the way it was suppose to be.. so idk if maybe that has nething to do with it? maybe somethin happened from it being up on jack stands for so long? i havent really taken any time to look it over yet, just thought i'd be lazy and see if anybody had any input first lol. but anyway, any advice or pointers would b greatly appreciated.
Old May 30, 2008 | 11:49 PM
mewantkouki's Avatar
no
Bleed your brakes.
Old May 31, 2008 | 04:50 AM
norachelhere's Avatar
fails.....
agreed...
air in the lines...
we both get rep, cuz we're right...
Old May 31, 2008 | 09:00 AM
95hondaC's Avatar
Thats what i figured.. jus wanted to see if any1 had a second opinion
Old May 31, 2008 | 09:08 AM
need4speed101691's Avatar
if u bleed the breaks n it still dont work it ur master it the same symptoms as a clutch ...it go stright to the floor n u got to bring it bac up urself?? pm me if u need help bro
Old Jun 2, 2008 | 12:35 PM
95hondaC's Avatar
Bled the brakes.. didnt help at all. It almost seems like the pedal isnt even engaging the pads or something. Any ideas of what could be wrong?? I'm stuck.
Old Jun 2, 2008 | 08:27 PM
no
If you are running the stock rubber lines, they may have dry rotted on you. Inspect the brake lines for any leaks. Is your brake master cylinder losing fluid? Use dot 3 fluid, it is recommended and really easy to bleed because it is less viscous than dot 4, 5, etc.
