sr20det help needed
Old May 26, 2008 | 04:34 PM
WhiteNgold's Avatar
is underwater
Exclamation sr20det help needed
put my first sr red top in my s13 and it runs......OK. its been running "ok" 4 about 2 weeks. "ok" isnt good enough 4 me. builds boost and pulls til boost is done building. once it hits 14psi it goes down to like 10psi. sometimes it goes to like 17psi and goes back down. newayz, it quits pulling after boost is built, its sluggish, it sux. vaccum read +-0 at idle and as i give it a lil tap of throttle it goes down to like -5 or so. shouldnt it be like -20 at idle? does this mean vaccum leak. bov is set tight. hks wastegate actuator, timing is dead nutz, fmic, all wiring is correct. ive done boosted cars b4 but never a factory turbo car so any help is much appreciated. thnx
Old May 27, 2008 | 03:45 AM
WhiteNgold's Avatar
is underwater
morning bump!
Old May 27, 2008 | 07:04 PM
lordofthemiasma's Avatar
RIP DJ YOU WILL BE MISSED
def a vaccum issue. should be -20 at idle. check your vaccum lines. freshalloy.com ftw when it comes to shit like this.
RIP my very best friend. DJ aka djzstang1 you will be missed dearly. I love you bro.
1995 240sx se
1992 240sx
1990 240sx se
1991 240sx hicas sr20det MDX
1991 240sx project coupe
1990 240sx drift beater hatch
1993 240sx sr20det
Old May 27, 2008 | 07:52 PM
kairojya's Avatar
Rojya Productions
anyone know what vac should be at in bar?
the only gauges/instruments i have are all in bar
Follow me: YouTube | Vimeo | 500px | Flickr | Google+ | Facebook
Old May 28, 2008 | 04:16 PM
WhiteNgold's Avatar
is underwater
thnx 4 that bit. ill try them and go over it again
Old May 29, 2008 | 05:49 PM
WhiteNgold's Avatar
is underwater
ok.... i quadruple checked vac lines, charge piping, and gaskets. no leak. could it be timing related? like intake cam or xhaust cam is not right? w/ my timing light, it reads -15 degrees. i read some places say to unplug tps to check timing but this just kills my engine. no codes either. ne info would help thanx.
Old May 29, 2008 | 05:51 PM
WhiteNgold's Avatar
is underwater
btw, i had to notch out cam angle sensor to get timing at -15 degrees. the closest i could get it before notching it out was -20 degrees. it didnt matter how i installed the cam angle sensor it would never get to -15. i so confused.
Old May 30, 2008 | 04:41 PM
WhiteNgold's Avatar
is underwater
oops... i did have 2 vac lines wrong. now it reads -20 and still runs like crap. ne more info? help.
Old May 30, 2008 | 07:00 PM
RubberBerner's Avatar
Sideways Maffia
1 inch of mercury = 0.03386 bar
so -20inHg=-.6772 bar
NOBAMA!
