I Really Need Help!!!!
Ok i have a 91 240sx Ka24de completly stock just recently i got up went to my car n i wouldn't start In April i had the same problem but i thought the battery was worn out so i replaced it.. A few weeks later the problem came bac brand new battery but the car would not start sometimes but sometimes it would with a jump so i was told it was the alternator i swapped out the old alternator n put in another one .. the car was running fine for weeks now i just went to my car to turn it on and i get nothing no lights no power no crank no Nothing.. I Really want this problem to go away if any Tr guru's kno wat it could possibly be please lmk i would greatly appreciate it.. Thanks
Ignition switch. I think that is deff what your problem is. Bad ignition switch. Go to a junkyard and yank one. You should be able to fit in your pocket. Good luck brother.
Ignition or battery cable. Odds are, you need new battery cables anyway, replace those to be safe.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
1973 VW Squareback
RIP Tim
try hotwiring the starter to see if it is the ignition switch. Put the key to the run position, then hit the starter with power straight from the battery, it should start the engine. If not, then it is your batter, or starter...
If it does. Shut the car off, and try to start it again with the key. If it doesn't, then it is your ignition switch.
hope that helps to narrow it down some for ya...
Ill try that tomorrow morning.. and Im going to buy a new starter frm the guy Two posts up Presidential so hopefully i get it goin after these suggestions.. thanks for the help guyz
