5spd conversion ?'s
Old May 14, 2008 | 02:04 PM
RydinSolo's Avatar
Unkown Member
Default 5spd conversion ?'s
if i get the lower harness for the swap, i dont have to splice any wires together do i? also will a sohc 5psd lower harness work on a dual cam
i have a dual cam right now and my friends car that the all the 5spd stuff is comming from is sohc 5spd..can i use his harness with out cutting any wires?
EF hatch-In the Mix
Old May 14, 2008 | 06:10 PM
shinmei2006's Avatar
no real need for a harness...and no real splicing either...
aside from jumpering the park/nuetral switch so the car will start...what you need to after that is wire your reverse lights
all you need is to take a meter to the auto harness.
plug it into the middle grey plug and find which one is the constant (green/blue on the fusebox side) and which one is the reverse (white/green on the box side) by testing em on a voltage meter and cut everything else off the plug.
plug it back into the middle grey plug off the fuse box, and run the two wires down to the furthest front plug (labeled reverse light sensor or something along those lines)...stick the car in reverse and have some look at the reverse lights, then plug it up to the tranny plug until they come on.
http://www.hashiriya.net
Old May 14, 2008 | 11:00 PM
RydinSolo's Avatar
Unkown Member
ok so i got down about the park/nuetral switch...
so i cut al the wires off the plug except the grn/blue and white/green or do i cut those 2 wires as well and then just run 2 wires down to the sensor?
EF hatch-In the Mix
Old May 15, 2008 | 04:05 AM
RydinSolo's Avatar
Unkown Member
also, i have the how-to from NicoClub printed out, and i was reading it and looking at the plugs last night at work...and i do not see the roght color wires that the how-to said...the white/green and green/blue..i do not see those anywhere coming out of either of the 4 plugs..well 3 plugs because the one i know is for the park/neutral....
Also if it makes a difference, the trans is from a single cam, along with the sensors..do i need sensors from a dual cam? and my harness is dual cam..would that make a difference
EF hatch-In the Mix
