anybody know how to bleed master brake cylinder??
Old Apr 24, 2008 | 06:19 AM
3SVERIZON's Avatar
GTE is out of bussiness ^
I hope the reason for bleeding the system wasnt fluid contamination (cause if it was then you should remove the master cylinder :replace: and remove lines from calipers and use brake parts cleaner to clean the contaminated fluid out and prevent it getting to the seals in the calipers) if your car has ABS there are also bleeders on them :some cars:
If it was bleed like regular with a contaminated fluid like powersteering (PS fluid eats away/damages most rubbers and seals and ABS pumps in brake systems and will do damage either right away or down the road
Sean Kriner
Crew Cheif / Lead Mechanic
*RACE CAR FABRICATION
*WELDING
*ENGINE BUILDING
*WIRING SERVICE
2002 Lexus IS300
2001 Lexus IS400
2000 F250 7.3 diesel
1990 Celica GT FOUR
Old Apr 24, 2008 | 06:26 AM
hoster2173's Avatar
shawn ur the one the did the master on my car yesterday well actually ur dad did but they work great now.. thanks
