Help me fix this and I'll buy you a beer...
Old Mar 12, 2008 | 04:00 PM
Clawhammer's Avatar
BELOW M3
Default Help me fix this and I'll buy you a beer...
...or a you-hoo if you're under the age.
Help! Red Dragon down! :'(: 240SX Forum / 180SX Forum / Silvia Forum: Nissan Forums / Infiniti Forums - NICOclub
Please!
2008 R1 | 2004 ///M3
Old Mar 12, 2008 | 05:22 PM
presidential's Avatar
OG Join Date: 6-15-00
Check your battery cables. Also, it might be a dead cell in the battery itself. I've had a battery that registered full voltage but was worthless under load. If it runs well with a jump, that might be an indicator.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Mar 12, 2008 | 05:38 PM
+Waldo+'s Avatar
Electronicals master ;P
damn bro just read through it on nico and they covered everything i woulda thought of...
that kinda shit is soooooooo frustrating! good luck man
Sponsored By Carrabba's
R.I.P. Tim Aldrich
Old Mar 12, 2008 | 06:09 PM
BoostLogik's Avatar
BoostAddict
I had a similar issue on my Mitsu where some of my power accessories were not working, popped the hood and found the positive battery cable "loose" around the post. The previous guy doing work on my car, forgot to tighten it down.
I read through your posts though and see that you've checked that though. Have you actually pulled the battery cables and wires leading up to the fuse box, to see if there is a break or bad ground? That sounds like it could be the cause for those blown fuses.
"Even through the darkest days, this fire burns, always"
Old Mar 12, 2008 | 06:10 PM
quiksilvia's Avatar
+1 on the dead cell
but check your connections and ground wire's
if worst come's to worst grab a multi meter and go to town
VV Pasco Meet every friday! VV
Awesome Pasco Car meet evey Friday!
Originally Posted by EclipseGT01
Try and get people at ANY car show to come around a Grand Prix or a Regal.... they simply wont because there is a lack of interest in those cars. Not saying they can't be fast... just saying that my WRX will always attract more pussy than your pontiac
[Insert Awesome witty car list here]
[§]Hellabroke Ballin aint free! [§]
Old Mar 12, 2008 | 06:44 PM
180sx-I's Avatar
DriftToy
+1 on battery connections
Old Mar 12, 2008 | 07:08 PM
Clawhammer's Avatar
BELOW M3
I've been going to town with a DMM like you wouldn't believe.
The best I can tell is that when I turn my key to on, my EGI relay starts buzzing until it pops the ignition switch fuse...unless I jump it with a wire (fuses are $3 each) in which case it gets so hot shit starts melting and would probably start a small fire lol. When I turn my key to on, the load side of the ignition switch fuseable link grounds. Can't find where/ why. I've been through the entire lower engine harness and traced all the wires back to the harness where it goes into the fender.
<---hates wiring gremlins
Old Mar 12, 2008 | 07:10 PM
Clawhammer's Avatar
BELOW M3
With the battery and alternator completely disconnected, the line side of the ignition switch link goes to ground...so it can't be the battery or alt., right?
Old Mar 13, 2008 | 03:43 AM
Durdan's Avatar
No Ants Drift Member
sounds like its time for a body harness. check up under your wheel wells and make sure you havent rubbed through anything
RIP Tim. i miss you, buddy
Old Mar 13, 2008 | 05:15 AM
DriftingDJ's Avatar
240LSX
find a way to disable the alarm before you do anything drastic. trust me eliminate the alarm out of the equation first.
