s13 dohc KA into a hardbody?
Old Feb 16, 2008 | 05:25 PM
IThaJokaI's Avatar
Hates cars...
Default s13 dohc KA into a hardbody?
I know its possible, I know its a bolt in matter because the hardbody uses a KA to start with. But my questions are. If I ran the KA24DE harness with ECU would I be able to keep my factory interior harness? Or would I have to use the s13 harness and get the cluster from the same vehicle. Or like I said could I use my cluster with stock harness to the DOHC ECU and still be able to read the gauges accurately?
Thanks for any help in advance,
-Mike
Old Feb 16, 2008 | 07:24 PM
BLK94EGCOUPE's Avatar
some nissan
When I swapped a KA24DE in my hardbody I pulled it out of a "01 frontier,I had the luxery of just buying the wrecked frontier for $500 and pulled the entire harness out and put in my hardbody along with the engine and tranny along with the frontier driveshaft which is a 1pc instead of the stock 2pc with support bearing also I took the interior harness and dashboard out and installed it in the hardbody to make everything work on the instrument panel RPM,Gas gauge,speedo,open door light,everything it came out nice till I recently sold it like a fucken dumbass and im in the process of building another hardbody but this time im going SR g/l to you pmme if I can help you in anyway during the swap
Old Feb 17, 2008 | 05:09 AM
IThaJokaI's Avatar
Hates cars...
See, I wish I could find a baller ass deal like that. But the thing is I never find good deals. If you happen to come across anything let me know. I will snatch it up ASAP!
-Mike
Old Feb 18, 2008 | 07:50 AM
some nissan
anyone else have info on a SR20DET into a hardbody...harness wise I know swap wise its a direct drop in
Old Feb 18, 2008 | 08:09 AM
IThaJokaI's Avatar
Hates cars...
nissancustoms.com There is a shit ton of info there on pretty much everything for hardbodies.
-Mike
