Diff question...
Old Feb 5, 2008 | 11:48 AM
Ph34r's Avatar
ΔxΔp ≥ h
Default Diff question...
Can I install the guts of a J30 diff into a S13 pumpkin?
Got parts all over and want a functioning diff. The reason I want to swap the guts is the J30 has ABS crap all over it and won't fit properly under the car.
Thanks
Old Feb 5, 2008 | 04:02 PM
longfellow2's Avatar
FORE:sight
Yea, you can fit any R200/V diff into any R200 pumpkin from what I understand.
EX - Im running a R33 GT-S VLSD in an S13 Open diff pumkin on my S14. And I just got a 4.36 fd and pumpkin from a GT-S skyline today from Epstein which I need to find another VLSD to put into.
Just make sure you remember what parts go on the left and what goes on the right.
Originally Posted by Epstein
Old Feb 5, 2008 | 05:22 PM
Boats N' Hoes's Avatar
i have a j30 in a s14 open diff pumpkin in a s13...lol
Originally Posted by CurbJacker
great a new fucking band wagon... now every fucking 240 and ricers gonna be saying " im going LS1" i hate this shit... ill stick to SR20... teenie bopers i swear.
So_Chem WE RUN SHIT!
[/CENTER]
Old Feb 6, 2008 | 10:38 AM
Ph34r's Avatar
ΔxΔp ≥ h
^Good, that is exactly what I am looking to do... lol
Old Feb 6, 2008 | 02:38 PM
robunicu's Avatar
Nicolai
so its easier doing it that way, rather then using the entire j30 diff with different axels?
PBM fender roller for rent!!
Old Feb 6, 2008 | 02:53 PM
oASHo's Avatar
Lace Up!!!
if you have both diffs already out of the car, i would think it would be easier, than pulling out your stock axles and replacing your stock axles if with ones from a lower year j30 if you dont have access to a lift and your doing it in your driveway.
Old Feb 6, 2008 | 03:07 PM
norachelhere's Avatar
fails.....
I just about to ask if you still had to use the J30 axels...
So unless you're looking to do the 5 lug swap by means of entire rear end swap, you're better off to just swap the guts of the diff out
right?
Old Feb 6, 2008 | 03:53 PM
WeinerBwai's Avatar
just go welded
but yea the guts will definatly fit into the diff.
Now, this is really quite simple, ok? Understeer works like this; you drive down the road, turn the wheel, but the car goes straight on, crashes into a tree and you die. Oversteer works like this: you drive down the same bit of road, turn the wheel, but the back of the car comes round like this, and you go off the road, crash into a tree and you die. Now, oversteer is best, because you don't see the tree that kills you.
Old Feb 6, 2008 | 04:40 PM
FORE:sight
right?
Axles are independent of the hubs, in that you can swap out any axle that has the same spline. And all R200 diffs use the same spline axles. So it will work with any car that has a R200 (240, 300, 350, J30, Q45(i think has an R200), ect..)
All you need is the proper Diff cover, Halfshafts and corresponding axles
All the guts can be swapped from one R200 pumpkin to another R200 pumpkin.
