chemical to clean engine gunk out?
His researching skill sucks
Pour it into just about anything that your car takes in, but do not leave it in there for long, it will eat away the seals and orings easily. Follow their recommended instruction. Product's been on the market for decades. Hence why it's so popular
i like mystery oil too. I dump a bottle in the crank case just before an oil change... Usually, the morning of, drive around all day. then drain it out. its kinda gross when you see what all comes out of a nasty engine...
Sea foam works better through a vacuum line...
I really like that lucas fuel injector cleaner. it says to put like 3 onces or something, but I use closer to 9-10 in a tank of gas, its the only cleaner that I've used that seems to make a difference as far as injectors go...
I don't recommend doing it at every oil, but a good motor flush goes a long way to clean gunk. The best one i've used is the CRC high mileage motor flush. It comes in a metal can. otherwise that one that advance sells isn't too bad either.
the down side to putting it through a vacuum line is that seafoam is hard on the spark plugs. doing a little "maintainer shot" doesn't do too much, but If you get as much in as possible, like half a bottle, then you run the risk of killing your plugs.... I don't know if it is directly caused by the seafoam, or if it is from all of the crap that it breaks loose...
yea sea foam sounds good. Ill try that fuel addative too. and yes Im a impatient son of a bitch. I research for like 2 seconds then post a thread. Im not always on postin tho...Ill go threw like a week were Ill post ALOT then you wont see a thread from me for months.
Grease Lightning
Project.O In Full Effect...
Ride(s)
Green Lightning 10r :'( Sold :'(
Project Silvia :'( Sold :'(
2002 BO Lexus Is300 Rip :'(
2003 BO Lexus IS300 Sport Design (Project Altezza)
2010 Black Louts 10r :'( Sold :'(
1996 200sx Ser gtir swap 350hp SOLD
***More to come***
Car Stereo Installer for hire
come to me for your Audio Needs!!!!
Ride(s)
***More to come***
