Safc ?
Old Dec 30, 2007 | 12:12 PM
93LowBody's Avatar
TR Balla Donor Supreme
Default Safc ?
Does tuning with an SAFC cause the car to pull timing ?
if so what amounts?
I plan on using an safc while im n/a and maybe turbo also.
Old Dec 30, 2007 | 12:23 PM
Asian Prince's Avatar
as far as i know, safc just allows you to mess with A/F and doesn't do anything to timing.
Old Dec 30, 2007 | 12:32 PM
93LowBody's Avatar
But the problem is works of the MAP instead of MAF and i was told when the MAP is changed so is timing.
Old Dec 30, 2007 | 12:45 PM
180SX's Avatar
Yes..a SAFC will alter timing.. sometimes by a lot. It does not matter if you have a MAP or a MAF car. Basically if take % out .. i.e. stick bigger injectors in, you will be telling the computer that your map or maf voltage is lower than what it actually is reading. Basically the computer thinkgs that the motor is under less load if you decrease the MAP or MAF value. This is why it spits out less fuel.. and more timing. The lower the load value.. the less fuel and more timing the ECU will output.
In other words... get injectors that are not massivley bigger than stock.
Martin
Old Dec 30, 2007 | 02:30 PM
93LowBody's Avatar
Martin
Ok thats what i thought. while im running a mild N/a setup will it be a problem from the timing pulled ?
Old Dec 30, 2007 | 05:09 PM
180SX's Avatar
hell no.. nissan uses such pussy ass timing on the majority of their motors, you can take like 20-30% out, while adding a turbo and still be ok
martin
Old Dec 31, 2007 | 06:07 AM
i retract my previous statement
Old Dec 31, 2007 | 12:12 PM
93LowBody's Avatar
you wernt wrong btw.. the SAFC just adjust map to make the car give less fuel but in doing so cause timing to change also.
Old Jan 1, 2008 | 06:59 AM
well i learn something new
