hardbody auto to manual swap.
Old Dec 15, 2007 | 04:53 AM
93LowBody's Avatar
TR Balla Donor Supreme
Default hardbody auto to manual swap.
So the auto in my truck is going out so its time for a manual swap.
Anyone ever done this swap ?
What transmissions can i use ?
240 5speed ?
other things i need to know?
and were is the best place to get parts ?
Old Dec 15, 2007 | 07:52 PM
RPM MOTORSPORTS's Avatar
NELSON
YOU WILL NEED SLAVE CYL. CLUTCH MASTER CYL. CLUTCH PEDAL, TRANSMISSION FROM 300ZX OR 240 SX AND OF COURSE A FLY WHEEL AND CLUTCH.DEPENDING ON MOTOR IN HARD BODY. CROSS MEMBER MAY OR MAY NOT WORK. IF YOU HAVE A V-6 YOU COULD USE EVERY THING FROM A PATHFINDER, CHECK OUT BIG 3 U PULL IT FOR MOST OF THE PARTS YOU WILL NEED. i AM IN THE PROCESS OF PUTTING A VQ30DE WITH 350Z 6 SPEED IN A 97 HARDBODY.
GOOD LUCK
ROY
Old Dec 15, 2007 | 07:53 PM
93LowBody's Avatar
thanks last time i went to big 3 they didnt even have a harbody. or any decent 240s
