exhaust leak
Old Dec 1, 2007 | 08:07 AM
JaxS13Racer's Avatar
Sold my sol for Silvia
Default exhaust leak
Ok I have a redtop sr20det that has a bad exhaust leak. It sounds like it is coming from the no. 3 or 4 cylinder area. I took the manifold off from the block and the gasket looks ok and I couldn't see anything wrong with the manifold it self. I'm pretty sure that it is pre-turbo, the turbo isn't spooling up like it is supposed to but it does go from vacuum to a couple of pounds of boost. Does anyone have any idea of where to look next?
Old Dec 1, 2007 | 08:13 AM
DriftingDJ's Avatar
240LSX
check the flange gasket in between the turbo and manifold. if it is that gasket replace it with a copper t2 gasket like from a TT 300z. If you have a cheap ebay manifold, looks for cracks in the manifold.
Old Dec 1, 2007 | 08:56 AM
-weekendwarrior-'s Avatar
Army Infantry
+1 cracks on the manifold suck. had to rebuild half my mani with thicker steel and made support brackets everywhere. it weighs like 10 lbs more
Old Dec 1, 2007 | 01:38 PM
I've got an XSpower mani so it's not the best but I didn't see or feel any cracks in it. I'll have to check out that flange gasket. Thanks and keep the idea coming.
