s14 white smoke
Old Nov 27, 2007 | 06:21 PM
PiNoYcLaSs's Avatar
Default s14 white smoke
Seems to only blow out white smoke when sitting at a traffic light for a few minutes when you step on the gas. Did a compression check and its showing 180 across the board. From this information is it safe to narrow down to a bad head gasket? Anyone seen a write up how to change hg's on ka24de??
Karl
Old Nov 27, 2007 | 06:36 PM
170k240's Avatar
Will Drift For Tires
your valve seals are going. when you change them, youre going to have to change the head gasket anyways.
Nissan North America - Canton
Old Nov 28, 2007 | 10:19 AM
-weekendwarrior-'s Avatar
Army Infantry
^ i thought oil burned blueish gray not white but either way replace the valve seals and the headgasket that'll do the trick cuz thats the only 2 things it can be
Old Nov 28, 2007 | 10:51 AM
170k240's Avatar
most people dont notice the blue in oil burn-off because its so close to white. but from what he/she described, the characteristics are valve seals
Old Nov 28, 2007 | 05:03 PM
Superluminal's Avatar
The Cyber Brain
...or turbo seals if it's boosted.
Old Nov 29, 2007 | 11:04 AM
PiNoYcLaSs's Avatar
My thoughts were valve seals also but I thought white smoke was an indication of the oil and antifreeze mixing? Theres a sweet smell sometimes when I turn the car off. Also engine has some oil drips in the garage overnight. Where could that be coming from??
Old Nov 29, 2007 | 04:19 PM
170k240's Avatar
take the whole thing out and stock rebuild. seriously, it prob needs it and it will take care of all of your problems lol
Old Nov 29, 2007 | 05:52 PM
PiNoYcLaSs's Avatar
thanks guys for the inputs, now only if i can figure out the FSM.
Old Nov 29, 2007 | 09:10 PM
170k240's Avatar
hahahhaha, thats a whole nother beast in its own. read the beginning on how to read it. it helps
