rear bumper melting
Old Nov 25, 2007 | 07:20 PM
FinaL's Avatar
Default rear bumper melting
ok since i gotten the car up and running i have no problems at all..butt after ahile my rear bumper is coated with black sute, and melteing,
also it back fires on idle butt i think thats b/c i have shitty plugs in it and havent changed them since i got it running, also i replaced cap rotor and wires ext and have no vacume leaks, runs fine all day with no problems
i like to fix this issue and have a clean rear end.
its a single cam if ur all r wondering AND i have no ecu codes at all..
can it be my o2sensor?
any ideas
also on a side note i would like to convert to power windows, ill be getting the doors and wireing to it. is it a simple plug and play or am i gona have to run wires?
buddy of mine is partying out his 240 and i got first dibe..
Old Nov 25, 2007 | 07:43 PM
Jonas's Avatar
ill sell u a rear bumper. champagne color. $10
Jonas
Old Nov 25, 2007 | 07:56 PM
FinaL's Avatar
i dont want a rear bumper it just melt again
plus i can get on real quick
Old Nov 25, 2007 | 07:58 PM
Silk_240's Avatar
Just Drive
well the black sute probably means its runnin' rich. but is the bumper actually melting, like running down and stuff?
Old Nov 25, 2007 | 08:10 PM
FinaL's Avatar
its melted a good portion and pretty much stoped
im ether gona cut it out some more to make it look nice or extend the ehaust 2in out abit
i just need to kno y its running rich i mean i have no engine codes and i found a page how to diagnose the ecu butt only for engine codes and not o2 sensor diagnostic
Old Nov 25, 2007 | 08:12 PM
170k240's Avatar
Will Drift For Tires
change the injector o-rings, they may be leaky. either that or you feul pressure regulator may be bad/going bad.
keep the melted bumber, its gangsta for realz
Nissan North America - Canton
-weekendwarrior-'s Avatar
Army Infantry
i'll take you up on that offer
pm me i can pick it up tomorrow
Old Nov 25, 2007 | 08:15 PM
FinaL's Avatar
man i hate to say it butt i did that as well
when i had the car running , shut it down i hear a hissing sound and sure enough it was an injector oring leak so i reapled that too
Old Nov 25, 2007 | 09:02 PM
FinaL's Avatar
forgot to menchin this before i am also looseing oil butt have no leaks?
could it be oil valve seals?
Old Nov 25, 2007 | 09:12 PM
Army Infantry
does your car smoke bad at take off cuz that would be valve seals but if its constant than its rings and/or if your not running a oil catch can and getting massive blow by
