I am having fuel and spark related electrical problems. I need insight!
Old Nov 12, 2007 | 11:04 AM
norachelhere's Avatar
fails.....
any updates?
Old Nov 13, 2007 | 04:39 AM
silvia tech's Avatar
Norachelhere way to hit the nail on the head. It would seem weird that both the fuel pump and then something ignition related failed. It does seem like 1 Sensor or the ECM creating both symptoms. Detriment don't forget that you not getting fuel in the first place might not have been the problem just the symptom. Check sensors that relate to both fuel and ignition in those sensor diagnostics it will tell you what you should be getting from the ECM so you will know if that is bad. It could also be a ground issue that is only making continuity some of the time so it could be loose or corroded since you have a Voltmeter measure continuity on the ground circuit.
For Tech Questions And Troubleshooting Call 352.229.2350 Or PM.
