DET or FMAX
Old Aug 24, 2000 | 11:13 AM
2000SE's Avatar
Realist
what is the highest psi a DET or DE w/FMAX kit can run on stock internals?
The glass is neither 1/2 full or empty. It simply contains 50%of its total capacity.
Old Aug 24, 2000 | 12:10 PM
Blood_Sun's Avatar
Im not an expert but Ive heard that 7psi is stock and some run around 12psi on stock internals. Can anyone else confirm this?
Old Aug 24, 2000 | 02:01 PM
Charles's Avatar
Senior Member
Originally posted by "Someone"
Correct maybe 14psi the limitation is the small turbo NOT the internals. Bolt on a bigger turbo and the internals will handle 400-450hp.
The DE engine WILL never make that kind of power with OEM internals.
89 240sx - SR20DET - 7psi for now...
00 EBP Civic SI
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old Aug 28, 2000 | 04:39 AM
2000SE's Avatar
Realist
on the contrary i know of 2 sr20des that are pushing 400+ on stock internals. the stock boost for a BB (bluebird) det is 7psi.
the DE is very capable of handling a turbo with 12psi as long as the motor pistons bearings etc... are in good condition. (I did more research this weekend. ALOT actually!) the internet is a very good tool! especially webrings!
thanks for your replies!
Old Aug 28, 2000 | 06:35 AM
Blood_Sun's Avatar
Cool keep up updated as to the progress of the buildup/transfer.
Old Aug 29, 2000 | 06:30 PM
Charles's Avatar
Senior Member
Let me clarify....the DE engine can not run that boost level on stock internals at stock compression ratio as a daily driven car. You might be able to get away with it once in a while at the track etc. That high of a boost level on the DE engine will not last long.
00 EBP Civic SI
92' Nissan 240sx
08' Tundra
