Lookie what I found in my garage!
Yep, it's the old T25 & manifold from my old SR blacktop. Kinda thinking of doing a budget low-boost KA-t build now since the turbo has minimal shaft play.
Has anyone done a KA-t with a SR T25? I'd just like to know what to expect or if I shouldn't even waste my time with this thing. And no, I am not going to rig the hot water heater into the car (as awesome as that would be).
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
1973 VW Squareback
RIP Tim
Don't really want it to put down a lot of power, just more than what I've got. The low 200's would be just dandy. I've since cleaned it up, it looks decent now.
1973 VW Squareback
RIP Tim
1973 VW Squareback
RIP Tim
no its not.
healthy t-25 @ 1 bar setup right will do 280/280.
or in most cases at least 210/240. with a powerband equal to that of an n/a ka.
craig, id hit up ka-t.org and freshalloy. some of teh setups there are freaks, but the majority of people can put down good FUN power. the best part is you can use all SR parts, minus the manifold, so its all plug and play. s13 sr fmic will fit ka with a longer TB coupler.
Glad you understand what I'm after, Dan. It's not meant to be a powerhouse, it's just a stopgap until something better goes between the shock towers. Just something fun that makes cool noises that I miss.
1973 VW Squareback
RIP Tim
1973 VW Squareback
RIP Tim
yes, def ka-t.org
probably half the people on there are in the same boat as you and will have exactly the same seup
just remember to search there and dont post a thread. because what you'll be asking has been asked millions of times
Nissan North America - Canton
turbo you have
255 warbro
sr injector's
taped pan
oil feed and return
rerout coolant line's
safc
IC setup/with BOV
down pipe
manifold
and that about get's you going!
255 warbro
sr injector's
taped pan
oil feed and return
safc
IC setup/with BOV
down pipe
manifold
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
