question about s13/s14 rear axles
I ♣ Baby Seals.
on
Are there any differences between the s13 and s14 rear axles? As far as diameter, length, hub/bolt patterns go...
I ♣ Baby Seals.
on
thanx for the info. The flanges on the s14 halfshafts look to be the same as the s13's, so I figured that part should bolt up at least, or am I wrong?
The 3/4" length that sponsored is referring to (which also pertains to ABS S13's) has nothing to do with the axles or axle placement. As long as you're using the same bolt pattern (5x1 or 3x2) they're the same between S13 and S14.
