s13 ka engine cutting off
got a 93 ka in it and the engine just cuts off after a couple minutes of running and sometimes not. i drove it from port richey to bradenton and no problems. but now the car turns over fine but doesnt spark up. when it does start its runs fine with no problems but then cuts off quickly without bogging down or sputtering. sounds electronic like possibly the coil.
suggestions. go.
suggestions. go.
details on this cutting off please.
Jonas
Jonas
well the engine turns over fine but doesnt spark up but maybe once every day. when it does start it starts quickly and normal. but when it doesnt start is just turns over and over and never sparks up. when the engine does turn on it will run for a couple of minutes and then just cut off. the engine doesnt bog or sputter it just cuts off? i mean thats about all there is to it. ive made sure all the plug wires are secure just incase of a loose connection but still nothing.
if im missing what you are asking perhaps you can give me direction on being more specific. thanks
okay. i think i might have found the base of the problem. i went to change the plugs and when i pulled out the wire there was TONS of oil in each cylinder hole. so i guess the oil has been drowning the plugs? So sounds like a valve cover gasket replacement? AND i can't get to the plugs because the rubber seal from the stock plug wires are all still stuck in there over the plugs lug thing. how the fuck do i get those out.
buddy, I'm trying to find time to make it down to bradenton again. I wish i could help ya out already, but hopefully you'll have this running by then...
yeah i replaced the plugs/wires and gaskets. it started up but still cut off after a couple of minutes. then it went right back into the old turning over and over but not sparking up. im new to electronics so i dont know what to check for when you say the module on the coil pack. what part of the coil and im looking at and what for? thanks a lot for help
