a/c making my car HOT
Old Jun 17, 2007 | 01:16 PM
kober's Avatar
Don't Drink And Drift
Default a/c making my car HOT
everytime i turn on my A/c my Temperature goes like 2 bars up.. and when i turn off the a/c my temp goes 2 bar down (about the middle)
I have a 92 Ka24de btw...
anyone have any idea what the problem is??? lmk thanks.
Old Jun 17, 2007 | 01:35 PM
RubberBerner's Avatar
Sideways Maffia
is the condenser fan working? I've never had a 240 with a/c so i don't know if this is normal...but you've probably got some sort of airflow issue.
NOBAMA!
Old Jun 17, 2007 | 01:52 PM
170k240's Avatar
Will Drift For Tires
yeah, your a/c fan may not be working. get some altima fans or taurus fans and get rid of that shitty a/c fan
Nissan North America - Canton
Old Jun 18, 2007 | 06:37 AM
burgy240's Avatar
Offset-----Less is MORE!!
This isn't the problem, but a Radiator flush and new fluid would probably be a good idea after you upgrade the fan/fix the problem.
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Old Jun 18, 2007 | 07:09 AM
norachelhere's Avatar
fails.....
yeah, that seems to happen quite a bit... the AC fan isn't working, you can either pull it out and replace it and hope that the new one works, or you can get some electronic fans, altimas or tuarus, and wire those in. that will also eliminate the need for the stock clutch fan... which is allways good...
Old Jun 18, 2007 | 08:43 AM
I'm Phucked's Avatar
army pilot
if you have never done anything to your a/c or radiator and your car is very stock you might want to remove your radiator and get the 15+ years of dirt leaves and road shit that is sandwiched between the condensor and radiator.
make sure fans are working and problem should be solved.
In a relationship you are either man or woman choose wisely [fortune cookie @ Ling's garden]
Originally Posted by Tackleberry
thats an insult to a circus
Old Jun 18, 2007 | 06:59 PM
kober's Avatar
ok thanks everyone
Old Jun 19, 2007 | 10:11 AM
fails.....
i found a small child sandwiched in there...
its crazy the crap that gets stuck up in there...
